need to decide which sr to go with
Old 02-01-2004 | 04:04 PM
Baloo's Avatar
i was wondering how hard it would be to swap into a 1989 240sx the s14 sr20?? will you have to change alot more?? i have no clue everyone i know has a s13 swap in an s13. and doesn't the s14 have variable valve timing that is what i heard? and are the s13 and s14 sr parts interchangeable?? thanx
Old 02-01-2004 | 04:40 PM
The only thing that will be different is the wiring, it will be a little tougher because of the VVT. Other then that, i think its basically the same as the S13 SR. And some parts are interchangable, ill try and get a list later on, the super bowl is on
Old 02-01-2004 | 05:54 PM
Baloo's Avatar
yeah thanx i posted it then it came on and is the VVT kinda like vtec???
Old 02-01-2004 | 06:23 PM
tegg_gsr's Avatar
i think so
Old 02-01-2004 | 07:00 PM
Baloo's Avatar
so the s14 sr20 would prob be the best sr to go with out of the two
Old 02-01-2004 | 11:43 PM
PANGES's Avatar
sorry for thread stealing but is'nt the rb25det just as easy to swap in as the s14 and cheaper?
Old 02-02-2004 | 01:23 AM
No, the RB25 is more expensive. You need to do more modifications in order to fit correctly.
Old 02-02-2004 | 01:57 AM
Baloo's Avatar
okay since we got on this subject Hyjnx you were doin a rb20det swap and stopped why??? the reason i was thinking the s14 sr20 was it had more power than a s13 and bolted right in i was going to go with the rb20 since i found a great deal on a front clip but i thought that instalation was goin to cost me an arm and a leg
Old 02-02-2004 | 11:50 AM
Installation is not ganna cost you an arm and a leg for the RB20. It should be around the same price. The wiring is much easier then the S14 SR, and the only large mod to do is swap cross-members with the R32 one. Do a little shaving on the sway bar(Or get adjustable sways), a little on the downpipe/turbo elbow and a little on the hood(not visible from the outside) and your set. Its a lot easier then it sounds. I stopped on my swap because my funds ran out, and didnt have enough time to finish it. I picked the wrong time to do it.
Old 02-02-2004 | 11:52 AM
Baloo's Avatar
for real i think i am just going to go with what i wanted in the first place and plus i found a really good deal on a front clip rb20 here i come
Old 02-02-2004 | 12:04 PM
For the price, i think its gatta be the best bang for the buck for a 240sx
Old 02-02-2004 | 12:05 PM
Baloo's Avatar
okay i know this is a way off sub but do you know wher i can get a stroker kit for it?? i have read that they have been strocked to 2.4 but i have not found one
Old 02-02-2004 | 12:16 PM
you got me. Maybe rb20det.com has some info, or meggala.com
Old 02-02-2004 | 12:18 PM
Baloo's Avatar
okay i will try meggala already check rb20det
Old 02-02-2004 | 06:45 PM
tegg_gsr's Avatar
just turbo your ka instead of rb
