Just swapped Redtop Sr now some problems.
Old 11-12-2007 | 07:37 PM
S13NismoStyle's Avatar
Took a while to post, but i took back my redtop last thursday(11/8)which was a 3 hour drive and picked up my black top sr. I started on the swap at 9:30 and had the sr up an running by midnight. Which is pretty good i think. It runs great and it also came with an ARC induction box. Which i checked out and they appear to be pretty expensive.
But i got another question. Where do you guys hook up your wastegate vacuum line. I have mine going from the wastegate to the large vacuum nipple off the throttlebody/intake mani. Also were do you run your boost gauge from. I have mine running off the cold pipe from the side mount. But i was told that i need to Tee into the line that runs to my wastegate for my boost gauge. Because for some reason my boost gauge is reading 10 psi at wot and i dont think that is right.
Old 11-12-2007 | 09:23 PM
crazydrifter's Avatar
the wastegate vacuum should go to a nipple you make in the hot pipe, the boost gauge should make a tee with the throttle body and the fuel pressure regulator, and the vacuum line next to the one that goes to the fuel pressure regulator on the throttle body should go to the BOV.
Old 11-13-2007 | 04:57 AM
Oh ok, well im using a stock sr sidemount so ill have to figure out a way to hook up my wastegate. whats the best way to do it, just weld one on? thanks for the input
Old 11-13-2007 | 10:32 AM
TypeX180's Avatar
don't you have an internal wastegate?
side mounts=gay..haha they max out on like 8psi..change it buddy
Old 11-13-2007 | 02:52 PM
im ordering a fmic this friday, but i just used that sidemount to get the car running.
Old 11-13-2007 | 03:03 PM
if you have a stock side mount there should be a nipple for the vacuum line already on it.
Old 11-13-2007 | 05:11 PM
i have a nipple on the cold pipe. I think the nipple on the hot pipe has been cut off and plugged before i got the sidemount.
EDIT: i did not see a nipple on the hot side, can i just use the nipple on the cold pipe?
Old 11-14-2007 | 07:36 AM
positron's Avatar
I'll take that sidemount off your hands when you put the frontmount on!
Old 11-14-2007 | 04:46 PM
we might be able to work something out positron. Well i re-ran all my lines correctly and now im reading the right boost and 22 psi vacuum. is that normal?
Old 11-16-2007 | 02:43 PM
22 is really really good actually
Old 11-16-2007 | 03:47 PM
  #26
yea its normal going to idle my vacuum would dip down to -23psi and settle at -20psi
JonathanRuiz
SR
24
04-15-2008 09:54 PM
Goatspunk
06-16-2007 05:07 PM
james_s14
11-15-2004 07:01 AM
00p5
09-19-2004 10:02 AM
NcTwOfOuRtY
02-18-2004 08:08 PM
