How hard is the RB20 swap?
Hello everyone.
Im extremely new in the world of 240s. Infact, not even a day has past since I got mine. Its a 1992 rolling shell. I bought it off of a friend for $200 .
Ive been looking into replacement engines and stumbled upon this forum. I found a number of interesting offers on RB20DET engines. My question is, how difficult is the rb20 swap. I have rebuilt and installed 13b rotary engine sin rx7s before but have never worked with a 240. I have an engine lift and the right tools available, but difficulty wise, how would you all rate it. It seems like a spacious car to work on and Im interested in the power output of the rb20.
Does then engine bolt right into place or do I need custom mounts? Do the stock driveshaft and differentials work or do I need different ones? Any input would be useful. Thanks in advance
Re: How hard is the RB20 swap?
Originally posted by Cloud7659
Hello everyone.
Hello everyone.
Benefits include:
A)Higher compression for more off boost power
B)Newer engine meaning apossibility of lower milage and newer technology
C)Higher displacement meaning more potential
D)Better turbo pushing more air at the same CFM
E)Stronger transmission meaning it can handle more juice before popping
Deficits include:
A)Higher price tag
B)Need a custom driveshaft
C)Lower redline
Deficits include:
A)Higher price tag
C)Lower redline
So Im set with the differential. for the rb25 I would need a xmember, maybe custom mounts (which I have no idea where to get), and for the rb20 I need the same excedpt no driveshaft. I actually don't know where to get these parts, can you guys point me in the direction of a list of places or maybe a writeup. Thanks for all the help so far.
No crossmember needed, use the 240SX one....mounts from www.mckinneymotorsports.com MAY want to get a limited slip differential if yours isnt...
i've been wanting to do the rb20 swap for a while now but everyone keeps telling me... no man it's not worth it. it's not a very good motor blah blah blah
what's the lowdown? what are common problems for it?
I love my Rb20's putting down 300 plus with bolt-on's. They bolt right in with our mounts, are cheaper than SR20's, sound better, have more torque and out rev the RB25, yes the 25 has more power stock because of displacement, but hey the 20 is cheaper, more money for mods.
Eric
Eric
Out rev....that is such a TIRED arguement. Stock redline on an RB20 is 7400...stock on an RB25 is 7200. Doesn't make up for the fact that most RB20DET's dyno at around 180 at the wheels in stock trim in a 240SX and the RB25DET's dyno for around 240 at the wheels. 200RPM still don't make up for about 60HP less!
RB20DET WAS a good motor in its time, but it was replaced by the RB25DET for a reason! The Rb20 just didn't cut the cake anymore so they replaced it with more displacement, higher CR, better turbo, Variable Valve Timing, stronger transmission, etc...
The RB20 is a viable choice for its pricemark, however if you can afford the extra, hold out for an RB25.
Thank and good night.
hmm....now Im really confused. The RB20 drops right in, no mounts and no xmember necessary, also its compatible with the driveshaft of the 240. Basically, its a drop in and go engine (except for the basic water pump, timing belt, hoses, etc.) But, ofcourse, its weaker than the 25. I knew this but 60rwhp difference? Thats alot!
Now, the RB25 starts out costing more + the $ for the kit from mckinney. It comes out to about 1700 more than the RB20. Not to mention that most engines don't come with intercoolers so theres another pretty penny right there.
Its a really tough decision. Could I increase the rb20's performance to 240rwhp with less than 1700. Probably yes, but Im guessing it would be less reliable. Confusion.
