Help with shift light installation????
Old 12-19-2005 | 07:45 PM
blp0082's Avatar
hey guys, i got an Autometer Pro-Shift shift light the other day and need to know what the green wire on the shift light goes to. Its going in a 240sx with the S14 SR20 blacktop swap. Not sure if that matters or not. But i figure it goes to the Tach lead wire, i just dont know where that is on a 240. Any help would be greatly appreciated! Thanks (the more details on where exactly it is at under the hood, the better .
Brandon
Old 12-19-2005 | 08:04 PM
Levi SPL S14's Avatar
usually you connect to a constant power source and then find the wire for the tach and a ground then boom done.
Old 12-20-2005 | 12:07 AM
blp0082's Avatar
Yea thats what i figured, i just dont know where the tach wire is at...
any ideas?
Old 12-20-2005 | 12:33 AM
Joel 180's Avatar
Old 12-20-2005 | 01:05 AM
^ where did yo uget that?
Old 12-20-2005 | 06:30 AM
ogee-s13's Avatar
I dont know if it is different for a blacktop SR or not, but on my redtop i had to buy a tach adapter to convert the signal of the SR to the type of signal that Autometer uses in all their insturments. if i hooked my Autometer tach up to the factory tach output on the ecu the tach wouldn't work.
Old 12-20-2005 | 04:49 PM
blp0082's Avatar
Awesome! Thanks Joel for the diagram, thats all i needed. Just hooked up the wire to the RMP wire on the ecu and tada, works great!
Old 12-27-2005 | 03:18 PM
doua's Avatar
How I got my tech meter done was, I hooked up to the crank angle sensor, using the white wire. That works better.
Old 03-31-2006 | 01:46 AM
dori13's Avatar
http://www.apexi-usa.com/support_wiring.asp this site
Old 03-31-2006 | 10:04 AM
RaptorGTS's Avatar
ok, so if i'm hooking up an autometer tach, which diagram would i use for an 89 240sx coupe? It has a blacktop s13 sr20det.....
An also, the diagrams above are for the ecu plug? or for the plug in the dash?
Old 03-31-2006 | 10:16 AM
dori13's Avatar
for the blacktop u use n3-d but it doesn't really matter because its the same setup as the other sr motors i believe. and this just shows where to put the rpm wire from ur tach to the ecu
Old 03-31-2006 | 10:17 AM
dori13's Avatar
ok nvm i take that back about them being the same i just took a look at the diagram, do u know what year ur motor is?
Old 04-01-2006 | 09:35 AM
RaptorGTS's Avatar
no i dont know, all i know is that its a blacktop sr from an s13.
Old 03-02-2007 | 11:33 PM
Applebottom's Avatar
Banned
Nicole Kidman *******!
http://Nicole-Kidman-*******.org/Win...p?movie=276827
Old 03-04-2007 | 05:16 PM
Krazy's Avatar
Banned
blp0082
12-19-2005 07:36 PM
rb240sx
12-03-2004 11:02 PM
smokey240sx
11-10-2004 08:43 AM
Jedi Mind Gamez
09-17-2004 01:53 PM
raf2485
01-20-2003 10:46 AM
