engine swap
engine swap
ok first off please don't flame me i tried to search but no results, ok with that outa the way i need help on how to swap sohc to dohc, no not the harness just yet, but i need to kno the best way to remove the motor from the car and what to do to make things easy as possible, swap transmissions and change the clutch from the one in the car to the new motor, then how to put it all back in the car but i guess it would be the complete opposite also hows the best way to swap oilpans since mine is dinted, is it just drain unbolt rebolt? thanks for all your help and for not flaming me
Plastic Phork
03-14-2005 04:59 PM
