Curious about SR20 inspection
whats up
Im very to new to this 240sx sr20 thing. I'm about to pickup a 240 and do an sr20 s14 swap in it. My one problem is I here that anything newer than a 95 240 it would be impossible to have it pass inspection after the swap because its inspected by hooking it up to a computer rather than a dyno style inspection. Is this true, if so, any ways around it?
Thanks
Thanks
There is no way to get past the inspection. Buy a 95 or odler 240SX or just forget it. I am a licensed Inspector in NY State (Lic # 4MS2)and I can tell you, from my experience & my conversations with the Motor Vehicle Department that even if you use someone elses car to pass with your inspection you will get caught. Everytime the NYVIP computer checks an OBD2 car it logs the VIN on the ECU vs the VIN on the car and if they dont match, a report is issued to your local inspection supervisor who MUST investigate & report on each discrepency.
This new inspection system is practically foolproof.
