anyone know anything technical about sr20s
anyone know anything electrical about sr20s
Im having technical problems with my 240. for some reason i wasnt getting any power to my fuel pump, i cheked the fuse box and one of them called the egi pump(whatever the hell that is) looked like it was broke on top, i replaced with my bro's from his 240 and it turned over, but as soon as i put it in gear and tried giving it gas it craped out and that fuse or relay(not sure what it is) made a buzzing noise. I need some advice of what to do.
i just replaced the fuel pump relay and it turned over and then once i put it in gear it turned back off, and its still buzzing, my friend checked the fuel pump and one of the wires looked almost detached all the way and we put it back on with solder iron and still no luck, we even pulled off the fuse box under neth for loose wires and still nothing. my friend checked the ecu and nuthing came up. I wonder if i grounded out the fuel pump. it sucks if i did cause it is a brand new walbro fuel pump
God
10-03-2005 08:18 PM
pnoystyle86
08-11-2004 05:07 PM
