Rearend Build-up
Rearend Build-up
I WANT TO MAKE A ENGINE SWAP PUTTING A 385 STROKER ENGINE WITH 500 HORSEPOWER, 700R4 TRANSMISSION IN A 89 NISSIAN 240SX. WHAT CAN I DO TO THE REAREND TO MAKE IT TAKE THIS MUCH HORSEPOWER. OR DO YOU THINK A 9'' REAREND CAN BE PUT UNDER THE 240. ANY IMFORMATION ON THIS WILL HELP. THANKS
Rearend Option
Hi,
Limited slip differential offered from Kaaz can handle up to
1,000 hp without problem. You may have to consider a stronger
axle though. Maybe R32, R33 Skyline or 300ZX TT axles might
work best to hold your horsepower.
Regards,
Ray / Kaaz USA 1-888-522-KAAZ(5229)
Email: newportcars@kaazusa.com
Regards,
