Help my output shaft won't go all the way in.
Old 08-14-2003 | 08:40 AM
180sx Drift's Avatar
OK, here is what I did. I got a J30 Differential changed out the ring gear with original, and put it in the original pumpkin fits perfect! But now, my J30 longer output shaft won't go all the way in. Is there an alignment problem? Do I have to align something??? The smaller one goes in without any problem. I hammered and step on the longer output shaft but it won't go in. But it comes out easy.
I appreciate any help.
Old 08-14-2003 | 12:25 PM
SHIFT_Lock's Avatar
odd...are you sure you have the sides correct? may have gotten them mixed up.
Old 09-29-2003 | 11:27 AM
rudeboy's Avatar
did you get it workerd out?
did you use the j30 case too?
Old 10-01-2003 | 07:57 AM
So far I don't have any problem. But I need to put it in all the way through. Someday...
I used the ring gear from my 240sx and 240sx pumkin. The output shaft is J30 and lsd is J30.
Old 10-02-2003 | 12:09 AM
rudeboy's Avatar
the sides could be wrong like shift said.
or your circlip could be bent
i woulda used the whold J30 unit
angrymonkeyS14
10-01-2010 07:48 PM
twofotisx
07-09-2007 07:15 AM
gunbbang82
01-12-2007 07:32 AM
Carparthookup
09-21-2005 04:26 PM
redline808
03-09-2005 02:23 AM
