HELP clutch pedal problem
I have a 95 with an sr in it and I was driving and everything was fine, then I pull up to a stop sign and pressed the clutch in, and the pedal went to the floor and didn't spring back. I looked under the dash around the pedal and it seems as if a bracket that connects the clutch pedal to the rod that goes through the firewall has snapped. Has anyone had anything like this happen? How do I go about this, is it just a simple bracket I get from Nissan or what? Any help would be greatly apprecaited since my car is stranded right now. Thanks a lot.
you can't drive it without the clutch?
Its not that hard, the only trick is first.
For the future, its a good trick to know.
I would think a dealership would have it, but check out your local auto-zone, see if they can get one. <-- prolly cheaper
Bumnah
03-24-2008 01:32 AM
chitodsr
01-05-2008 12:34 PM
x3240racer
03-12-2007 04:17 PM
Matt_240
11-04-2002 06:22 PM
