do I have to chage the pressure plate everytime I change clutch?
Old 12-22-2004 | 02:04 AM
jackyliem's Avatar
can I just change the clutch plate and resurface the fly wheel? cuz my clutch is slipping and I am hella broke.
Old 12-22-2004 | 03:30 PM
Re: do I have to chage the pressure plate everytime I change clutch?
normally you change the disc and the pressure plate at the same time, including a new t/o bearing. Flywheel resurface is also mandatory when changing clutches.
Maybe you should have got a new clutch first instead of buying suspension.
Old 12-30-2004 | 05:04 PM
1995 240sx's Avatar
be careful with gitting the fly wheel resurfaced
with todays clutches they are made to a lot tighter tolarances and if the plates and fly wheel and all do not line up just right you could be looking at a sliping cluth even though the parts are new
Old 12-30-2004 | 05:24 PM
then again his car is 14 years old, so 1990 tolerances
BlackZenki82
01-03-2009 08:51 PM
fadedsilvia
07-11-2008 03:36 PM
redtopS13
01-19-2005 09:08 PM
duckman240sx
04-06-2004 08:00 PM
altimate94
05-14-2002 11:25 PM
