Clutch still not working right
Old 10-08-2003 | 12:55 AM
silvia180SX's Avatar
I swapped in a KA and a 5 speed in my 89 240 and I've been through a lot with this little project but it's still not done. There seems to be a delay when I let go of the clutch. When I let go the engine revs and the car goes forward just fine, it just doesn't have the normal feel of engagement. I can't spin the tires in 1st at all. Any ideas?
Old 10-08-2003 | 04:43 AM
rudeboy's Avatar
did you use the stupid little damper box?
if you did then remove it
if not just go under the dash, pull the cotter pin on your clutch lever.
take the rod that goes to your slave master, and adjust it.
you can screw and unscrew it.
off head i cant think of what way you'd want to go...
\but that's what i did.
gave my pedel ratio more feel and more clamp.
i think i unscrewed mine.
my pedal releases up towards the top but clamps hard
Old 10-08-2003 | 11:55 AM
Is the damper box the one with the line that goes back and curves back in? Also should I screw the adjustment fork toward the fire wall or toward the drivers seat?
Old 10-13-2003 | 07:53 AM
gmckey's Avatar
www.takamotorsports.com
go there and get their stainless steel clutch damper removal line. I got one for when I did the auto->manual swap on my 98 240, and compared to my friends 5 spd 97, my clutch feel is much stiffer and nicer. definitely worth the $45 shipped.
Old 10-13-2003 | 01:46 PM
As it turns out I was playing with the adjustment stuff so much that at one point I got it perfect and thought the problem was fixed. I left the MC bolts kind of loose so I could adjust it more after I drove it but that was a mistake. I drove it for 2 days and I lost more and more clutch to the point where it wasn't grabbing hardly at all and the clutch was getting magma hot. What I couldn't understand was why the problem was getting worse. The bolts were getting less and less tight every time I put in the clutch. Damn I'm stupid!!! When I checked the bolts they were finger loose. I made a last adjustment, tightened the bolts and now the problems fixed.
EJ253
10-11-2006 12:13 PM
EDog
08-11-2005 07:48 AM
silvia180SX
08-11-2003 11:09 AM
SilvaPwr
06-25-2003 11:35 AM
