bad throw out
bad throw out
ok i just got done putting a new transmission, stage one racing clutch, and flywheel. the problem wasnt getting everything in the problem came after when i started driving it. it was fine till about a mile down the road when i started to hear this clunking noise, and bearing hissing sound. i dont know if the hissing bearing is from a bad throw out or if its cause the clutch isnt blead right. so any info would be much appreciated.
thanx,
thanx,
you may of installed something backwards I had problems after I installed my new clutch kit but nothing like that so it wouldn't be a bleeding problem i don't think. if your clutch peal is tight and has tons of preausre then it doesn't need to be bleed. i only had to bleed my system cuz my clutch pedal wasn't getting any preasure and it was just sticking to the floor.
so all i can think of if your clutch pedal was tight and had tons of preasure then it doesn't need to be bleed.... so you may of installed the clutch disc backwards or maybe even the throw-out bearing or didn't put enough lube on the bearing.
But if it comes to your bearing just took a sh*t... i have an extra brand new throw-out bearing for a 92 that i'm trying to sell. I never used it cause when i replaced my clutch my old throw-out bearing was still good and didn't need replacing so 25 bucks if ya need it.
nismoman
12-10-2006 06:29 PM
slcmuffinboi
12-04-2005 10:24 AM
silvia180SX
12-10-2004 12:58 AM
