Basic CA info/FAQ
Basic CA info/FAQ
this information was borrowed from the CA forum from NICO. Credit is due to those guys.
http://forums.********.com/zerothread/136061
Displacement - 1809cc
Bore - 83mm
Stroke - 83.6mm
Compression - 9.5:1(DE) 8.5:1(DET)
Horsepower - 135 HP @6400RPM(DE) 175 HP @6400RPM(DET)
Torque - 115 ft/lbs @5200(DE) 166 ft/lbs @4000(DET)
Tune up stats;
Timing marks -The six marks on the crank pulley read clockwise are -5, 0, 5, 10, 15 and 20 degrees respectively.
Timing - 15*BTDC(DE(T))
Idle speed - This is set via a valve solenoid on the intake manifold. In the center of the plenum aiming to the front is a valve with a gold cylinder with a plug on it. Unplug it and adjust the idle speed with the 10mm bolt on the back of the valve then plug it back in.
Idle speed - 800RPM(DE) 750RPM(DET)
Spark Plug - NGK PFR6A-11 or equivalent Gap - 1.1 mm
Fuel Injector - Top feed, 370cc
Oil filter - Fram 3682, 3614 or equivalent (4qts with these)
Stock Cam Specs- CA18DET
Type - Lash
Cam Duration(IN) - 240°
Cam Duration(EX) - 248°
Cam lift IN(mm) - 7.80
Cam lift EX(mm) - 8.50
Lobe center angle (IN) - 120°
Lobe center angle (EX) - 120°
This thread is going to be dedicated to common upgrades, D.I.Y. upgrades, no-no’s, and other general CA18DET information. We are going to leave it open, not so much for discussion, but for you guys to add information to it. Lets try and keep questions out of here, and just add information. If you have a question, start a new thread asking specifically what you want to know! Thanks
1. Use CA18ET water pump only, or use both the CA18DE water pump AND CA18DE pulley. The DE pump will not properly center the stock pulley, and that's why people have their pumps busting and their fans flying off.
2. The stock O2 pipe will need to be replaced with an SR pipe if you want to use an SR downpipe. Or, you can cut, rotate, and re-weld one of the flanges.
3. DSM 450cc injectors are a PERFECT fit, with no machining required. To make them fit, you need to replace the manifold-side o-rings on the DSM injectors with the slightly smaller CA injector o-rings. Since they're smaller, they stretch a tiny bit more, and decrease their overall diameter to the correct size.
4. Turbo upgrade options: SR T25, T28 and beyond. Fitting an s13 SR20DET turbo is a bolt on affair! All that is required is you clock the compressor housing about 10 degrees (with a pair of snap ring pliers)! S14 and S15 turbos are similarly easy to install, but since I have never done those myself, I will leave it up to someone else to verify this fact.
5. A word of warning for people planning to use the garrett gt28r/rs with their stock manifold - its a pain in the ****. You will need some custom exhaust work if you don’t use the stock CA o2 housing (which fits like a glove) and you will have to either use several exhaust manifold-to-turbo gaskets or dremel the manifold as the compressor housings are too big and will not clear the manifold even with the heat shields off.
**edit: this was originally posted by tim in an old thread. I personally fit a gt28r (s14 turbo) with no problem under my stock manifold without even clocking it. with one turbo gasket. so... take this however you want to**
6. Pulsar GTiR Turbo has a turbine-to-downpipe flange that is rotated slightly so that the downpipe seats a little too low and a little too far to the driver's side of the car. This makes it impossible to bolt one exhaust hanger properly, but you can bolt up one of the two bolts. The misplacement, which is about 1 inch out of place along the diagonal, causes the downpipe to vibrate against the frame rail. A grinder can alleviate this problem, so the turbo can still be a lower priced alternative to the S14 and S15 T28 units. It does flow slightly more than the latter two units, but there will be other expenses involved so if you are looking for something with easy fitment and less hassle, steer clear of this turbo.
7. The eBay ssautochrome t3/t4 t70 turbo kit for ca18det on US 240 will not fit (the one they sell for $500 range). Its not a T70, it is exact copy of T61. The turbo exhaust housing will hit on master cylinder by about 2inches. No matter what you do. It will hit. Think RHD if you’re set on using their t70 kit. Use a regular smaller t3 (instead of a t4 back housing) and the manifold itself should clear all right. I’ve also heard rumors that the manifold will crack in about month of hard driving, but they do offer a lifetime warrantee, and other members have had them honor the warrantee without problems. Another issue with this kit is that the wastegate springs are set to be 14psi not a 5psi like they said. They also claim that the wastegate is adjustable, but you can’t lower the boost below 14psi.
8. Be careful when purchasing the ssautochrome t28 manifold. Apparently they released a group of manifolds (the first ones of the newer “race” equal length design) that don’t fit right. The original non equal length ones are fine, and the newer race ones are fine, but people have had issues with some of the middle models. There’s no real way to tell which ones are good, and which are bad from what I know. Someone correct me if I’m wrong…
Bore - 83mm
Stroke - 83.6mm
Tune up stats;
Type - Lash
If you are looking for parts, tell the autoparts store that you have an 88' Nissan Pulsar NX SE. It will be the correct part 99% of the time!
Please note: Nissan NA is no longer making many of the gaskets,pumps, ect, for the CA18DE that was in the Pulsar. They should all still be able to be purchased from a parts store though (Advance Auto, O'Reilly,ect)
NISMO motor mounts-
11210-RS520
11220-RS520(IDK which is left or right, but which ever is shorter goes on the exhaust side of the motor.)
11320-RS541 (trans mount)
ARP FLYWHEEL BOLTS-Same as a pinto. 6 in a package. 151-2801
Oxygen Sensor CA18ET 200sx Bosch 13276 $47.99
Spark Plugs CA18ET* 200sx NGK PFR6A-11 $Varies
PCV Valve CA18DE Pulsar NX Bosch PCV142 $2.99
Thermostat CA18DE Pulsar NX 491-180 $4.99
Thermo Gasket CA18DE Pulsar NX Felpro 35228 $0.89
Water Pump** CA18ET ???Part Number anyone???
Upper Rad. Hose KA24DE 240SX L-564 $7.99
Lower Rad. Hose KA24DE 240SX M-563 $7.39
Oil Filter CA18DE Pulsar NX Bosch 3400 $5.49
Alt Belt 4pk855 $9.99
PS Belt 4pk845 $8.99
AC Belt 4pk840 $8.99
* Exhaust side needed
** Includes Gasket
Other Spark Plug Options:
PFR6/BCPR6's for standard (gap of 1.1mm)
PFR7/BCPR7's for lightly modded (gap of 0.8-10mm - see what works for you)
BCR8's for high boost applications. (gap 0.6-0.8 dependant on boost level)
Oil filter 15208-H8911 Ryco Z386 or Ryco Z145A
Door bump rubbers 01658-J7000 (Skyline R31)
Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces
Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head
Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner
Intake manifold gasket 14035-53J10 (SR20 all)
Turbo inlet flange gasket 14415-75F10 (200SX)
or 14415-17M00 (S13 all) The Aust 200SX one fits.
Turbo outlet flange gasket 14445-26E00 (S13 all)
Engine front oil seal 13042-42L00 (CA18 all)
Engine rear oil seal 12279-18V00 (CA18 all)
Oil pan seal front 11121-01F10 (CA18 all)
Oil pan seal rear 11121-01F15 (CA18 all)
Head gasket 11044-51E00 (CA18 all)
Head gasket 11044-50F00 (SR20) until 9/92
Head gasket 11044-50F01 (SR20) from 9/92 till 7/93
Head gasket 11044-50F10 (SR20) from7/93 onwards
Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits
Engine gasket kit 10101-56E25 (CA18DET)
Engine gasket kit 10101-50E25 (SR20DET)
Engine gasket kit 10101-51E26 (SR20D)
Flywheel Bolts 12315-55M00 $2.18
Valve grind gasket kit 11042-51E25 (CA18 all)
Valve grind gasket kit 11042-50F25 (SR20 all)
Fan belt 11720-V7301 (CA18 all) L = 855mm
Fan belt 11720-52F00 (SR20 all)
Compressor belt 11920-V7301 (CA18 all) also suits power steering pump
Compressor belt 11920-30R10 (SR20 all) also suits power steering pump
The following have proved problematic.
Water pump 21010-V5528 (CA18) until 8/90
Water pump 21010-V5529 (CA18) from 8/90
Water pump 21010-52F00 (SR20 all)
Use a CA18ET waterpump from an S12
Thermostat 21200-V0201 (CA18 all) 82.0 C
Thermostat 21200-V0206 (CA18 all) 88.0 C
Thermostat 21200-53J00 (SR20 all)
Radiator cap 21430-01F01
Radiator hose - upper 21501-35F10 (CA18 all)
Radiator hose - lower 21503-35F00 (CA18 all)
Radiator hose - upper 21501-52F00 (SR20 all)
Radiator hose - lower 21503-52F00 (SR20 all)
Bonnet bump rubbers (large) 62840-D0100 (Skyline R31)
Engine coolant 10120-89904 Castrol
Dash switch back lights Nissan Aust, have similar types
$11.00 each **** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each
Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ).
Wheel nut 62840-21001 (R31 Skyline)
Brake pads See service info page. Bendix and others.
heater hose w/valve part 02-0036 or p/n ch1649 same as 1988/90 holden commodore 3.8ltr
(needs to be cut slightly)
Headlight globe Who cares Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam.
Rear Dampers
( shockers ) See Nissan Dealer or Nismo KONI. Part no. 80-401-081 sports kyb.
Approx $315 a pair.
Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 or Z201
Air Filter 16546-V0100 (same as R31 Skyline) K&N high flow reusable type P/N 33-2031-1
Spark plugs 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm)
Spark plugs 22401-53J16 (PRF6B, SR20DET)
Crank angle sensor 23731-85M10 (CA18 all)
Crank angle sensor 23731-50F01 (SR20 all)
Coolant temp sensor 25080-89903 (S13 all)
Steering Rack Boot (LHS) 48203-10V25 (same as local 300ZX, mabey R32 also)
Oil pressure sender unit 25210 89920 (generic nissan??)
Oil pressure sender 25240-89920 (S13 all)
Cam shaft timing belt 13028-51E25
Cam belt idler bearing 30BD219DWAX
Cam belt tenioner bearing. 35BD219DWAX
Clutch Master Cylinder rebuild kit. PBR Aust. K8690 (contains pistons).
K7689X (rubber components only).
Clutch Slave Cylinder 3062069F03
S13 Main Handbook (English) Nissan Publication SM9E-OS13G0 $230 tax ex.
RS13 Service Manual, Main Issue (Japanese) Nissan A008009 $143 Tax Ex
SR20DET S13 Engine supplement Nissan A008011 $187 Tax Ex
SR20DET S13 Wiring supplement Nissan A108012
crank sprocket - 13021-D4200 - $29.26
woodruff key - 00926-51900 - $1.02
crankshaft plate (behind sprocket) - 13022-42L00 - $1.78
Turbo Manifold gaskets -> head:
14036-D4201 (x2)
14036-D4202 (x2)
KA24 and CA18 use the same radiators (Unlike the SR) with both ports on the USDM passenger side
http://www.raretrick.com seems to carry quite a few CA products, including SAMCO CA18DET upper and lower radiator hoses as well as turbo hoses.
Feel free to add any part numbers or prices, or to correct any of the above prices/numbers. This list was created awhile ago, and some stuff might not still be valid.
NISMO motor mounts-
11210-RS520
** Includes Gasket
Rear Dampers
Approx $315 a pair.
14036-D4201 (x2)
14036-D4202 (x2)
