S13 people with 6.5" front speakers..
Old 11-26-2005 | 10:46 AM
Shark_MegaByte's Avatar
How much should I be worried about depth when buying new 6.5s for my doors? Will Kenwood KFC-1679ie or 1689s fit all right? If not, what kind of depth/mounting depth do I need to look for?
I have some adapter places to mount 6.5s, but wasn't sure what effect they will have on depth.
Old 11-27-2005 | 04:27 PM
KerosineK's Avatar
When you go to buy some speakers take one of the stock ones in with you and compare it to the speakers you want to buy.
Old 12-26-2005 | 06:44 PM
mastershake86's Avatar
I just installed new 6.5 inch speakers in the doors of my s13 and they clear everything fine. The speaker brackets for the 4x6's make the speaker stick out, but if you mount it flush it should clear no problem all i had to do was drill 3 holes in each door.
Old 01-23-2006 | 09:45 PM
LA_phantom_240's Avatar
if you are going to install 6.5's where you had 4x6's, i would recommend making a piece that bolts up to the original holes that the plastic mount for the 4x6's went using MDF, 3/8 will do just fine. Any thicker and the foam surround on the cone will vibrate slightly against the door panel.
Also, try not to get any speakers deeper than 2.5", ive heard that if you go any deeper your window wont roll all the way down.
ill try to post pics of mine if i get a chance.
Rabbi
04-08-2008 10:24 PM
drifterz73
05-09-2007 06:57 PM
middlerth
West Coast/Hawaii
33
10-21-2005 12:15 AM
Gonad
04-12-2005 08:00 PM
cherishzm
05-15-2004 04:04 PM
