new sub enclosure
new sub enclosure
well i finally finished my sub enclosure for my s13 fastback, i wanted to retain the spare tire and useable space in my trunk as well as keep the weight down and keep it all looking as factory as possible, here is the pic of it, i wish i would have taken pictures of the build process, but i totally spaced it while i was in the zone of fabrication
thanks guys, it took some planning and a few attempts to do, tried a few different ways before i got the right one, i will try to get some type of write up of how i did it posted when im not so tired, long day at work
BTW, do you think there would be a market for these?
i think ud be able to sell 10-15 of these on the various forums. Depending on coupe or fastback, sub size, and sub mounting depth. in a coupe i think ud only be able to fit a 10" unless it was angled with a smaller mounting depth u might be able to get away with a 12"
If you produced a clean enclosure that could be installed with out modification i think u might be able to get about $100-150 bucks depending on quality and fitment, just because it looks nice on the visual side people will be picky if the backside dosent look clean. So you would have to figure out how you would combing fiberglass, wood and whatever materials that you used, also having it fit like the one you made people will expect the same
well im thinking if i can get some spare time at work i am going to make a few of these that will be drop in side panels with the box part of it like mine is, we'll see how the schedule is for me, ill let you all know how the progress is on them
i would buy one.. if it would fit my jlw6v2 in my fastback... my sub is kinda heavy tho =/ atleast its not a w7. If you could fab me a box like that for my fastback whta would fit my w6v2 and have that oem fitment look and sounded good i would buy one for sure
