Keyless entry for '95 240SX SE???
Old 03-13-2004 | 12:58 AM
Originally posted by dkdeleon
you can program them by turning the ignition to the on position then switching the valet on then off 3 times then turn the key off and hit the remote button 1 time or hold it down for 3 sec. I caint remember wich one but one of them should work. it does have a valet switch doent it? hope this helps
Isn't it done with the drivers door pin switch? I remember way back a tech did it with my 200SX, but I'm not sure if that was what it was for
Old 03-14-2004 | 11:33 PM
TeckniX's Avatar
weird.. more more.. I wanna learn how all this just 'program' itself!!
Old 03-27-2004 | 03:17 AM
dkdeleon's Avatar
NO, the door pin switch is to arm the system after programing.
to program use the vallet switch.
Old 03-29-2004 | 05:01 PM
RandyJordan's Avatar
you can always go to best buy or circuit city and buy a whole alarm system
they will also install it for you
Old 04-21-2004 | 04:31 AM
SilviaS14KA24DE's Avatar
For OEM stock keyless entry systems 95 <
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds (taking the key out all the way, then back in).
3.Hazard lights should flash
4.Put key back into the ignition & turn to run position but do not start.
5.Hit the lock button on the remote
6.Hazards should flash. If there are additional remotes go to step #7 if not goto step #8.
7. Unlock and lock the doors with the lock switch on the door and goto step 5.
8.Pull key out and open the drivers door and then close it
9.It should be set
Old 05-04-2004 | 08:17 PM
KozyNissan's Avatar
Originally posted by rameek
For a 97 Altima for the little "clicker itself" $120 and an additional $80 to program it....
So i said F dat, i have approx. 8 seconds to put the key in the ignition once the door is open before it goes off...
So F' Nicolas Cage i'm usually gone in 5.5 seconds add 2 more if i have my son with me.....O add eternity when i'm wit da wife...
Omg dude im laughing my a*s off right now, but that is so true. LMAO
Old 05-19-2004 | 01:31 PM
uhh i just did a thread on how do reprogram it. Make sure you do it right.
Old 05-23-2004 | 02:30 AM
Krazyballa3's Avatar
hey i just bought my 240sx SE like a week ago... and the person who i bhought it from told me to go to the nissan dealer ship to enable the alarm... and i went there adn the guy told me the remote has nothign to do with the alarm... he said my alarm was aftermarket at first till i pointed out that it s an SE which came with a keyless entry... then... he told me to check the fuse.. cause thats the first thing he would check... then i was thinking to my self... is there a fuse for the alarm... well i didnt really care because the security light was flashing when the car s looked so i assumed if there was a fuse it was working... so then i am stuck with this non working alarm... silvias14ka24de... can you go over the instructions again... for the second remote becuase i have 2 and none are working
and i tried ur instruction but i believe something might be missing... it would be nice if you can double check them and re do them detaily thanks a lot
SilviaS14KA24DE
02-21-2009 03:23 PM
Purple240
11-20-2005 01:52 PM
smokey1
01-23-2005 11:33 AM
Krazyballa3
06-16-2004 09:40 PM
impact_grn_yosh
11-07-2003 04:47 AM
