head unit wiring issue - no power + antenna stuck up
Old 07-18-2007 | 10:18 PM
Cmon daniel, why not use a test light? I have a multitester and a test light, but IMO the multitester is a pain in the *****, I think the test light is more convenient.
Old 07-19-2007 | 02:53 AM
Initial Daniel's Avatar
Well, it may not be a problem with some older vehicles, but I was always taught to use a meter just for the simple fact that most test lights are self-powered, so if you were to accidentally hit an air bag wire, it could potentially cause the air bag to go off.
Meters aren't always going to be the easiest way to test, considering you have to ground it, and then if you don't have aligator clips(with bed of nails), you have to strip wiring, etc...
...but it is the safest way, and definitely most accurate to see what kind of voltage you're getting if any. Thats all. If you do just want to use a test light; just be careful, and be aware. Most air bag wires are yellow, thick, and clustered together so you know--but it's not always the case. Definitely vehicle dependant.
Old 07-19-2007 | 06:29 AM
kable's Avatar
i just wanted to make sure the power wire to the head unit wasnt cut in some place which was a likely possibility after all the splicing i had done. figured that was good enough for the task at hand.
Old 07-19-2007 | 06:07 PM
Get a wiring diagram and check the 12v wires. Make sure they're connected correctly or to the right wires. If push comes to shove, and it's a real bad mess back there, just clean it up and start over. Let us know if you need anything else. :]
Old 07-19-2007 | 06:38 PM
kable's Avatar
i got it all solved if u read post 14...i appreciate your help..it was a fuse...just had to find it!
Old 07-20-2007 | 12:00 AM
Yeah Daniel! Christ! Close this thread!
Old 07-20-2007 | 03:58 AM
Ahaha, sorry. Thats good though.
onelove240
03-22-2008 08:50 PM
Badazz_240
07-24-2006 05:44 AM
darook
08-13-2005 06:42 PM
Wish_itwasJDM
04-29-2005 10:01 AM
Paul_Boz
10-01-2003 11:26 PM
