Door speakers s13
first remove the bolts on the door handle and inside(behind) the power window, then there's a bolt in front of the door, you can't see it with the door closed, remove that one, then start pullind the panel out, but aply force evenly, do not pull hard on a corner all by it self, i pulled on the front end and the panel craked on the top, then you gona start hearing the clips go pop, they are usually at the corner of the door pnel, near the ends, bottom, and corners. they are made out of platic, if they break they sell them in autoparts store in a litle pakage, then after you get it loose, pull it on the front up a,d away from the door, try to push it out, dont pull it too hard, the disconect all wires, and ur done, i guess.
Yanman233
09-07-2006 05:29 AM
Gonad
04-12-2005 07:00 PM
l2aine
06-03-2004 07:38 AM
