Constant power wire?
Okay, Okay. Here we go.
I installed a new CD player in my car a while ago, and I have had the same problem since then. The CD player always has constant power to it. I turn the car off and remove the key, the music just keeps on going. I have dealt with this by just turning the CD player to "off" Now it's really irritating me (having to turn it back on b4 driving again) So What could be my problem? what color is the constant power wire and remote wire in the S14? Or any other solution or point in the right direction?
Re: Constant power wire?
If that's not the problem, then you can put a relay between the main power wire (constant) and then hookup the coil relay to a switched source, i'e cig lighter + wire, for example. Get your hands on a test light and probe around in the harnesses for a decent switched source.
I'll switch them later on today and post back with results. The only reason why I asked was that I tried a test light. I couldn't find a constant power, even with the connected wires. i'm thinking the guy before me accidentally ripped out the remote or somethng.
EDIT: IDEA!
I re looked over my wiring and noticed all my "power" wires are taped together. as in red-red+yellow-yellow all in one bundle. I havn't gotten around to switching them (its damned cold) But, think that's it?
EDIT: IDEA!
EDIT: IDEA!
EDIT: IDEA!
