alpine problems
alpine problems
I just installed an alpine cdm-7861 into my 93 240 (kinda old stereo)
i had to cut the stock plugs off of the harness. and wire them directly to the alpine harness.
anyway, ever since i put it in, when i turn my ignition off it resets my clock, also i normally take my key out then get out of my car, i cant do that no because my seatbelt wont retract unless the igntion is on. also you know when your playing a cd and you turn your car off how you turn the ignition back on and it picks up from where it left off, i have to completely turn the cd player back on to hear music again.
IDEAS?????
thanks a lot for help!
IDEAS?????
When I was trying to weed out my wiring mess, there was a fuse I blew that controls the accessories when the ignition is off. My seatbelts worked all weird and my clock kept resetting. Theres a fuse that keeps the clock and 12v hots hot when the key is out, at least that what I could make of it.
thanks a lot guys ill check all fuses and let u kno if it works!!!
i read somewhere that i could have fried some little white box next to the fuesbox?? i dunno we'll see what happens!!
heres a pic of my car
for s13's, this is the best advice i ever got. step 1: drive to autozone step 2: buy a full pack of "Glow-when-they-Blow" fuses. step 3: replace ALL fuses. -now when i blow a fuse, i look in the fuse panel, pull out the glowing fuse (they glow when they blow, remember, and replace with new one. -it may sound stupid but its a life-saver for s13's, because when you look for a blown fuse, its always the last one you pull out thats blown.
Thanatos-S13
03-06-2002 03:26 AM
