4 gauge power wire to the trunk
I just got my 95 240 se and am looking to put a sub into the trunk th info that I really need is where is the best place to run the power wire from the engine bay to inside the cabin. It is a 4 gauge wire wire so I do need a fairly large hole to feed it through (it is for a hifonics zx7500 running a polk audio mm1204 sub). Ive already found a way to run the remote turn on wire and have replace everything else that needs to be done. I really don't want to have to do any cuting if thiat is possible. Thanks
The way I did it on my '95 was drill a hole by the firewall on the passenger side of the car. Choose carefully because you don't want to drill through any wires or anything. I then used a rubber grommet to get a snug fit on the power cable and ran it through the hole. From there I just ran it down the passenger side of the car, underneath the carpet to the amplifier in the back. It shouldn't be too difficult if you just plan it out first!!!
battosaii930
01-16-2007 09:12 PM
socals13guy
10-16-2006 03:07 PM
waystlandremy
05-16-2006 12:24 AM
